Point Eyelashes Down?
I see it's possible to have lashes curl up or not curl up. Is it possible to have them curl down? Kinda end of the night disheveled look?
    You can try turning limits off and using negative values... Not sure if that will work though.
  • asdf123asdf123 Posts: 167
    Tried that. Doesn't seem to have an impact
    If this is Genesis 8 then the actual morph is on the eyelash GeoGraft - relaxing the limits on the base figure, which is only a controller, won't relax them on the morph on the lashes.
    doesnt it have face rigging on the eye lids?  there was 3 bones iirc
