Iray HDRI Tookit - Support thread [Commercial]
KindredArtsKindredArts Posts: 1,354
edited September 2019 in The Commons
Hi!
I don't often do support threads anymore since most people know what they're doing, plus i ship a lot of content with read-me's now. This set may cause difficulties if you're new to daz however. Just like my ghost-light series, it can be a bit confusing if you're not sure what the purpose of the set is.
Iray HDRI tookit is based on the scripted matte function that's buried in the bowels of daz, and doesn't get as much love it should. All i could find on the subject was an old video by Mec, and a couple of threads here and there. There's also a lot more you can do with Matte functions besides simply shadow catching - you can play around with it's reflective capabilities too.
If you're having difficulties using the tools i've provided, or want to further discuss how to utilize them, pop a post down below.
Post edited by Cris Palomino on
  • DripDrip Posts: 1,269
    Can we also simply thank you here? This toolkit allows me (and probably many others!) the use of HDRIs that used to be way too confined or constricting to be ever considered suitable for use, simply by actually allowing some interaction with the HDRI. It simply increases the amount of space available within a scene, which is awesome. We're no longer confined to posing in front of that chair which is part of the HDRI, but now also on it and even behind it.
  • LyonessLyoness Posts: 1,641
    I'm so excited about this one.  I love my HDRI's and this is only going to make them better.
    insta buy.... required product for all!!
  • evacynevacyn Posts: 993
    I don't think I've ever put something in my cart so fast! And your promo images are brilliant. Like Lyoness said - required product for all!
  • fastbike1fastbike1 Posts: 4,084
    This product is absolutely ingenious! The promo videos clearly show the effects and easilt demonstrate the beneift of the product. Well done.
  • Leonides02Leonides02 Posts: 1,379
    This seems very cool, KA!
    Although I wonder if it's very difficult to manipulate your figures / props without being able to see the HDRI? Did your promo images take a lot of fine-tuning in the Iray preview mode?
  • Thank so much guys, i'm really glad you're happy with the set! It's a really sweet function that's been brutally underused so far, hopefully, everyone will take it in their stride and create awesome content. Really appreciate the support my dudes yes
    Absolutely! I do everything in Interactive mode personally, but i know a lot of folks have slower PCs (or don't want to leave their GPUs running full blast). I've added a section in the documentation on how to render a clean plate background and add it as an environment background in daz once you have your camera locked off. Once you have a visual representation of your scene, you can merge your characters and set up the matte tools without even touching interactive mode. Setting up your scene is super quick when you have the background set up, but you can't see how the gloss/shadowing looks unless you jump into interactive mode obviously.
    That is a brilliant solution which I never considered. Bravo! This is in my cart now.
  • I've added a section in the documentation on how to render a clean plate background and add it as an environment background in daz once you have your camera locked off. Once you have a visual representation of your scene, you can merge your characters and set up the matte tools without even touching interactive mode. Setting up your scene is super quick when you have the background set up, but you can't see how the gloss/shadowing looks unless you jump into interactive mode obviously.
    Excellent, i hope you enjoy it! Again, this solution is within the documentation which you can launch from your content library. If you get stuck though, i'll be here. Good luck yes
  • markusmaternmarkusmatern Posts: 614
    It jumped right into my cart... Quite happy so far! However no finished renders yet.
    To improve handling I used two viewports. A large one not in IRAY mode with the original camera. To tweak the obstructions I set up a small auxiliary viewport with a zoomed in camera. Make sure you leave the second camera at the same coordinates! I first moved the objects in the large viewport. For fine tuning I changed everything in the parameters pane setting up a smaller nudge for the critical parameters.
    Hope my description makes sense wink
    Post edited by markusmatern on
  • Dear KindredArts,
    I have a question concerning this product and I hope you don't hate me for asking noob-ish stuff! :O
    Does this theoretically enable me to first render a background on its own and then add a figure, place it e. g. on a couch, apply the geometric forms that'll give me the realistic shadows and then hide all the background? Would this let me render my backgrounds and characters separately with accurate shadows once I put the two renders together in Photoshop? Or is this exclusively for use with HDRIs?
    Dear KindredArts,
    You can render a background you assemble as a HDRI, and yes, then this should work perfectly. I posted a short guide on rendering your own HDRI here just 9 days ago. Though I do hope someone makes a more detailed guide of the process sometime, and hopefully expands it with additional knowledge and tweaks to improve the result. I know both the process and the guide have plenty room for improvement, and should possibly even have their own dedicated thread, but I think that at least I managed to make it understandable.
    Post edited by Drip on
  • KindredArtsKindredArts Posts: 1,354
    Hi Markus, thank you for your purchase! I never thought of using auxilary viewports but that's certainly valid. Definitely lock-off cameras though folks - just tapping W,A,S,D can throw off your perspective.
    Dear KindredArts,
    You can render your background and then use it as a background in either Daz or composite in photoshop. If you render with no HDRI at all in daz, but with the catchers/occluders/reflectors added, you get a result like i've added below. So yes, you can composite inside or outside of daz if you like.
    1500 x 1100 - 387K
    Post edited by KindredArts on
  • CybersoxCybersox Posts: 9,960
    By the way, I was just reviewing my way-too large collection and noticed that this product and the 2nd Ghost lights set don't show up in the store under either the Resources or Lights categories, which is where I would expect to find something like this, and that they're instead buried deep in the "props" section. Granted, they both use props at the core, but I can't imagine that many people would go into Props looking for something to modify lighting...
  • AJ2112AJ2112 Posts: 1,417
    KA you are brilliant !!! Love all your products yes  Best tools I've ever used.  Now, I don't have to render characters knees down HDRi Lol !  cause feet never plant on ground properly.  Have a lot of wonderful HDRi, but characters always looked out of place/position.  I even asked how to adjust HDRi in enviroment with no solutions.  Thanks for all your hardwork, dedication, bringing us fantastic tools smiley
  • marblemarble Posts: 7,500
    I just bought this but am at a bit of a loss as to what to use it with. I don't have many HDRi sets that would serve a purpose for creating scenes - especially interiors. If anyone can suggest a few, I'd appreciate it. I have lots of HDR skies and panoramas but very few foreground scenes.
  • barbultbarbult Posts: 27,579
    It doesn't have to be an interior or foreground scene. It is useful anyplace you want to put characters or props "into" the HDRI. This is an outdoor image I did recently with one of the Cake and Bob beach HDRIs from the Daz Store. See the two people "in" the water. I used Matte planes to accomplish that. (Full disclosure: I did not use the Iray HDRI Toolkit, but I used the same Iray Matte technology and technique. I assume the toolkit will make it easier and more accessible.)
    2000 x 1125 - 1M
  • davesodaveso Posts: 8,298
    I'm  new , sort of, but lost ..what is lock off camera? What is interactive mode?
    Thanks. I do realise that it can be used with any HDRi but I was hoping to use it with some - how do I put it - close-up scenery. Interiors, street scenes ... the kind of thing Stonemason is brilliant at creating with mesh. Perhaps he should sell HDR versions of his scenes?
    There's something probably here that may suit your fancy.
    edited December 2019
    Hi Marble, best solution would be to experiment.  Since purchasing HDRi kit, I've experimented non stop, see what works, what doesn't etc.......  Render a scene you would like to do close up scenary interiors, street scenes, let us know what you used.  And we can try to assist.  I've learned in 3D that there is no one method of achieving scenes.
    Post edited by AJ2112 on
    It isn't the use of the toolkit that I am asking about, really. I'm just wondering where I might find those interior or close-up exterior HDR images.
    Yes, that's where I found those I have already. I use quite a few of them for backgrounds but either they are panoramic or they don't render sharp enough for close up scenes. Maybe I'm doing something wrong when I put one in the Environment panel.
    I notice that KA hasn't visited this thread since September, by the way.
    Post edited by marble on
    Hi Marble, sorry couldn't help.  Goodness, didn't even notice KA has not been unavailable since Sept sad
  • Saxa -- SDSaxa -- SD Posts: 882
    Lots of the HDRIs are better just as backgrounds.  And agree many do lack a crispness.
    But take an HDRI like *THIS* from HDRI Haven.
    This is a screencapture of the HDRI at the website link above.
    And this is a screencapture at bottom of same page of what some people posted as zoomed in examples of HDRI usage.
    When I first saw this, it was like, Ok, that is cool how that huge HDRI can be zoomed in that far, and still looks good up close.
    To me this was probably as good as it gets.
    A creative use of HDRI and 3D assets blended together.
    If you really like crisp, think you are stuck rendering 3D objects.  Full 3D renders just look better 99% of the time for my eyes.
    That said, KindredArts HDRI examples look pretty darn good from a story-telling POV.   Really like his motorcycle example.
    And some postwork on the HDRI could maybe help get it to look the way you want.
    Personally I still use HDRIs for background landscapes, some of the interiors, the sand or rock beaches and skies, and otherwise, it's all 3D.
    In 12 months hopefully RTX3080Ti is out and hopefully has 24GB VRAM.  Or may have to eat potatoes for a long time and buy a Titan.
    2213 x 1217 - 229K
    1904 x 975 - 200K
    Post edited by Saxa -- SD on
    Agree entirely with your post. KA's promo examples do look good which is why I asked the question. I wondered whether he might share where he found them.
    As for the GPU - I sold my beloved iMac so that I might buy a 2070 Super for my PC. Have now abandoned that idea since 4.12 has so many problems which only seem to be addressed by throwing lots of VRAM into play. I can't afford a 24GB GPU so, hopefully, the 3070 range might come with a decent amount of VRAM but I am not holding my breath.
  • mikethe3dguymikethe3dguy Posts: 515
    edited February 2021
    In terms of shadow-catching, does this product provide any darker shadows than the "Enable Iray Matte" function already included in DS? My typical scenes are interior and so any HDRI lighting I've got is simply what spills through a window. The majority of my lighting is via spotlights and emissives. With those lights the Iray Matte function only provides shadows that are a whisper of what I'd get on a regular solid surface, and that's causing me a great deal of grief. Does this offer a solution for that?
    Post edited by mikethe3dguy on
