hair will not tween doubled framerate
WendyLuvsCatz
I discovered something interesting about dynamic hair
if you double the framerate after simulation it snaps back on those alternate frames
interesting as I have simulated it at one frame a second without obvious issues rendering 30 FPS
but doing it 30 FPS then rendering 60FPS get a very obvious snapping between frames
seems there is some sort of threshold for tweening
a video showing the issue
first and last clip simulated 30fps and slomo rendered at 60fps
yet middle clip 1fps simulation is ok rendered 30fps but of course same duration
seems trying to slow it by doubling framerate is not possible
