Anyone using Dynamic Sheets in DS 4.6?
Eva1
Hi, I'd like to be able to use Dynamic Sheets in 4.6 - I've just managed to install it after a few tries, so it's showing up in the Content Library (installed in My Library), but there are no settings to morph it , just the usual transalation, roatation and scale options. I've tried downloading and installing all 3 file versions, and I know my way pretty well around the library structures (both DS and poser type).
Has anyone used this in a DS 4.0 version?
Post edited by Eva1 on
They are Dynamic which means you need to use the Dynamic Clothing Control to drape them over your item.
You can find the Dynamic Clothing Control (DCC) by going to Window > Panes (Tabs) > Dynamic Clothing. This is the basic control for dynamic clothing which comes free with DS4.6
Thanks very much!:) I've never used that control before, nice to discover it:)
Also, if an item has different shapes (clothes styles, sizes, etc.) it doesn't have parameter dials to control morphs, it has shape options in a drop-down menu in the Dynamics tab. Not all of them do, some have different cloth objects for different shapes.
I got the Dynamic Sheets. What a wonderful gift, at that price of 1 dollar! I've been wrestling with Dformer and incomplete tutorials just to have a blanket drape over a figure. This does it in DAZ3. I don't seem to be able to edit some of the collision parameters in the dynamic tab, they show up but are greyed. However, I recommend reading the Wiki -under Daz Help/search for Dynamic. There are several articles, since I only use 3, I suggest the search for the later versions. Attached is my 2nd try which was successful. This was Genesis1 with M4Pajamas, Modern Bed, and Dynamic Sheet.
