Male Below the Waist Elements with Which Figures.
Fauvist
in The Commons
For each generation of male figures from Michael 4 to Genesis 8, which products include the male anatomical elements?
In your runtime folder, what are they called?
Will the anatomical elements for one male figure work on every other male figure of the same generation?
With the anatomical elements attached to a figure, what happens to pants when they are loaded onto the figure?
Thanks
M4 didn’t include them with the base figure, they were included in the base morphs pack. From Genesis on they were only in Pro Bundles.
On another site, we did a few experiments regarding the ability to hide anatomical elements under the pants.
You CAN get a bulge with the anatomical elements if you have the right posing and changing some of the smoothing settings on the pants. As a Geograft, the clothing will react to it. However, as loaded in to the scene, the anatomical elements will poke through in the default pose.
What I want isn’t the anatomical element for nude renders, but just to make pants and bathing suits look normal.
They come with adult pro bundles only.
Do they poke through dforce clothing too?
This is possible. You just need to pose the anatomy in a way that it isn't sticking out, but lays more flat.
Then you increase the smoothing modifier in the clothing item so that it's simulating the surface of the clothing more than the default.
The male morphs usually include at least one bulge option, and of course there are always dForms.
I've found there are male anatomical elements for Daz3D figures on another site. Do those attach the same way as the DAZ ones? Is there some difference. I don't want to have to pay $50 for an anatomical element for each generation.
Probably, but you should probably ask there to be sure.
Have you ever created morphs using Blender? There are a bunch of tutorials out there on how to do this.
It would be pretty trivial to add a simple crotch bulge morph to a male character if all you want is some geometry under the clothing to fill it out.
fit control is half price, you can do alot of things https://www.daz3d.com/fit-control-bundle-for-genesis-8-females-and-males
This, when it is just about the bulge - why making it that complicated ?
https://www.daz3d.com/genesis-8-male-body-morphs e.g., you'll find a "Genital Bulge" morph in the "Hip" category
And yes this bulge is projected into/ on the guys pants, you can even set the limits off :)
