Can't get the DieTrying morphs to work [SOLVED items has been updated]
SylvanSylvan Posts: 2,719
edited November 2013 in The Commons
I downloaded the DieTrying morphs as I did with the older package.
But for the G2M I am unable to get them to show up in my tabs properly.
First, I put them here as was stated in the readme: Documents/Public Documents, but they wouldn't show up in my tab
Then I dropped them in: MyLibrary/Data/DAZ3D/Genesis 2/Male/Morphs and now I can only see a nails morphs in the tab, but no other DieTrying items...
I do have separate drives. I use C:, where I installed the main Studio 4.6 software and I have E: where I install all my items.
Perhaps that's where I am messing up somehow, but why will it show only that single nailmorph?
Post edited by Sylvan on
  • carrie58carrie58 Posts: 4,090
    Ummm according to your screen shot it looks like you are "clicked" on the figures head.......try "clicking" the main body and see what shows up .....
  • SylvanSylvan Posts: 2,719
    It doesn't matter if I select M6 as a whole, or body parts :(
    Also tried loading the base G2M figure but still I only see the nailmorphs, no matter how I select the figure.
    EDIT
    I went to sickleyield's page and I am not the only one who only sees the nailmorph.
    Seems it's a known issue.
    They seem to show up fine in parameters, just not in the shaping tab.
  • elusivealbumselusivealbums Posts: 0
    I downloaded it and most everything shows up fine (though since my Smart Content went to hell a long time ago, I only see them in the Parameters tab.)
    The only different I notice between it and genesis is that the breast morphs are gone (because the figure is male? That's reasonable but it's not really 182 morphs anymore then, is it?)
  • RogerbeeRogerbee Posts: 4,460
    If they're all there in Parameters, then why not just use them from there!? I've never used the Shaping tab anyway, probably because I'm used to the parameters. It's not that they don't work, you just use them in Parameters instead of Shaping and they will.
    CHEERS!
    Everyone uses a different workflow :)
    Also, I discovered the morphs were actually present under the parameters tab after I visited the ShareCG page and I am using them from there.
    Yeah, it was visiting the ShareCG page that got me to download them.
    CHEERS!
  • BejaymacBejaymac Posts: 1,943
    They show up in the Shaping tab for me just fine, so I guess they have been updated.
    Still going to have to modify them though, as dumping all of the dials under Actor just doesn't cut it, @ vender's TriAx figures have Region codes for a reason so please learn to use the ****ing things.
  • KeryaKerya Posts: 10,943
    http://www.sharecg.com/v/73186/browse/21/DAZ-Studio/DieTryings-182-Morphs-for-Genesis-2-Male
    Paragraph says: 11/20/2013: Updated with DavidGB's settings to enable visibility in Shaping.
    And to Bejaymac: these are free morphs for V4 - and I personally am thankful to Sickleyield that they are transported to G2M - I have no idea how to do something like that ...
    Post edited by Kerya on
    Awesome, thanks for the info :D
    Cool, I'll go and check the date on my zip.
    CHEERS!
    EDIT:
    Got mine the day before the update! Now getting new versions.
    Post edited by Rogerbee on
