p.Con Planner
a program that allow's you to create your own room's quick and easy for interior designing, but also export's to collada so the geometry room's are in scale with Daz charector's after an import. it can also help converting 3ds model's to fbx by just double clicking on the 3ds file and then exporting to fbx, and also export sketchup warehouse model's used
you need to texture everything in p.Con planner to add UV map's if you want to add custom Iray shader's in Daz
Post edited by p0rt on
Looks like a very useful program.
its quick and painless, if you want todo the little detail's, you can import the geometry into https://www.freecadweb.org/ or another CAD program
Wow, thanks for the heads up.
ungroup everything in p.Con planner, before you start in the edit tab, then you can delete the 2d images and material all of it using the materials in the start tab, then edit material size, rotation, scale in the material editor under the edit tab
it takes no time, the attached image, is using this from sketchup 3d warehouse https://3dwarehouse.sketchup.com/model/u1cea3e17-954f-4d98-bc98-dac7b64a8571/House-3
Some of the full buildings arn't created using the professional versin of sketch though, so they arn't BIM architected, and will have 10,000 extra polygon's
Looks good. Maybe I can make a facsimile of the neighborhoods I grew up in, that would be fun.
