Shape Morphs for Making rounder 'anime' breasts and butts?
sjaammonssjaammons Posts: 185
edited September 2019 in The Commons
Awkward convo but here it goes:
I'm wondering if anyone can recommend any G8 morphs to help me sculpt some proper anime-styled breasts and butts on my figures. A bit iffy about posting images in case of breaking a rule, but short answer: Look at a Miku Miku Dance model.
Long answer: Anime breasts and butts tend to be rounder, less realistic-looking than normal breasts, and I'm seeking to capture that with my anime figure I've frankensteined with a number of morphs. The issue is the body, her breasts and butt have too much realism going on, and I'm seeking some morphs that could help exaggerate them into 'anime balloon breasts' as one friend jokinly called them.
So anyone got any suggestions for morphs that could help me capture this silly style?
Post edited by sjaammons on
  • Well I would recommend starting with a base as close as possible, like Aiko 8, The Girl 8, or Kanade 8, and then apply the morphs to achieve the specific shape you're looking for. If all you're focusing on are the glutes and breasts, the glute and breast control bundle might work for you: https://www.daz3d.com/glute-and-breast-control-bundle-for-genesis-8-female-s .
    Yeah, there's like a hundred shape sets just for those body parts around here and other sites. I would consider many to be cartoonish in proportion. Just look around at promo pics to try to find what you are looking for.
    I forget if it is included with the base or not, but there is a "breast implant" morph that makes the breast round. It might be in the Genesis 8 Female Body Shapes, one or the other. Like magog said, you probably want to start with toon like shape first. It just depends on what you consider to be anime style, since that could mean all sorts of things.
    If you are feeling frisky, you can create your own morphs in Hexagon. I promise it is not that hard. Since you just want to make certain areas rounder, this is pretty easy, and you can make them exactly like you want. You can use the Genesis 8 Dev Model which is included with the G8F Starter Essentials pack. You want this because it is easier for exporting and has no textures. The Daz to Hexagon bridge takes care of the export/import process for you. Load up the dev model, apply the morphs you want, then send to Hexagon. In Hexagon, you click the Genesis 8 name to highlight her, then click "Symmetry X" so that everything you do on side is duplicated on the other. There are only a few tools you need, all are in the UV & Paint section. The rather self explanatory "Inflate" and "Soften" tools are all you really need for this task. Click inflate and make the radius of the tool larger, about the size of the breast. Then just do your thing and do some plastic 3D surgery. The soften tool can clean up the mess and round out hard edges. You can also hold the shift key to make Inflate go in reverse. Do not change the subD or add or remove polygons or vertices. Just use the paint tools.
    When satisfied, send this back to Daz. Back in Daz, a box pops up. Give this morph a name, a unique one so it doesn't conflict with others and that you can find. You can right click on the path and select actor>chest, make sure reverse deformations is turned on, and click ok. Now in parameters do a search for the morph you created, and apply it. Boom. If you like it, you can save this as a support asset>morph asset. Click the arrow boxes to open the file path you gave it, so if you did go actor>chest, then that is where it will be. Click the box by its name, use your Daz name as vendor name (this doesn't make you a vendor). If all goes well you just made your own morph, and it will be available like any other morph you buy for all your G8 figures.
  • Yeah, there's like a hundred shape sets just for those body parts around here and other sites. I would consider many to be cartoonish in proportion. Just look around at promo pics to try to find what you are looking for.
    Thank you for that, I've never used Hexagon so thank you for the in depth advice. I'll try it when I get a chance!
  • I think GuhzCoituz probably has some morph sets close to what you are looking for over at Renderotica as well as his own site. GC Breast Preset for Genesis 8 Female and GC Booty Morphs for G8F in particular should fit the bill pretty well.
