Typing letters in library -> camera movement
When i type letter in library content library to jump for positions of this letter (press T to get on Thorne folder etc.), it's nice, but lately instead of this i get camera movement instead, which should not be working like this if i'm in content library and clicked on any folder. I'm on 4.8 currently, anything i can change to solve it? Worked right on 4.6 as i recall.
Disable keyboard navigation.
Hi!
It's Keyboard Navigation in the scene. I use later versions and I get this when using find search field; mouse a couple of pixels off the search field and viewport moves.
You can toggle it off (at least in later versions) with shift-K or click the icon near node selection and translation tools. At least this prevents the non-undoable camera movements. I don't know if you get library jump positions back.
-P-
Thank you for answers!
I hoped DS auto-detects whether to use it or not (disable it when i'm in content library tab with any folders choosed and enable when switch to other tabs), but seems like we should do it manually through icon or shortcut - OK!
p.s.
Shift-k works well, thanks again.
