duplicate formulars found in files
I have found a problem when I use DAZ ,it really confuse me ...
When I load some scene with G8F charactar ,or even open a new G8F charactar ,it took so much time ,and finally load it done and nothing is wrong in scene,but with a note everytime
It let me see the log ,and the log is full of the words like below:
2019-09-17 22:01:39.384 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/FBMVictoria8.dsf#FBMVictoria8?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Bend%20Control/Smoother%20V8%20R.dsf
2019-09-17 22:01:39.384 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5818): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/FBMVictoria8.dsf#FBMVictoria8?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Bend%20Control/Smoother%20V8%20L.dsf
pls help me crying
  • kyoreonakyoreona Posts: 213
    edited September 2019
    it appears even when I load a base G8F...
    but it's ok when I load a base G8M
    Post edited by kyoreona on
  • The could not find messages mean just that - there's a link, in this case to Victoria 8, from the Smoother V8 20L ansd Smoother V8 20R morphs which cannot be resolved as you don't have Victoria 8 installed. Since it's a correction morph that is needed only when Victoria 8 is installed and applied that is harmless.
    The messages have nothing to do with the Duplicate Formulas alert, you should be able to find log entries for those too.
    It's so strange
    I don't remember that I have changed my content...
    And why do a base G8F needs victoria 8 ...?
    It's so strange
    It doesn't mean that Victoria 8 is needed - it means that if Victoria 8 were installed that product would have extra morphs already in place to make sure it worked properly with Victoria 8.
    It's so strange
    I can never understand this strange thing...
    It never alert when I load a base G8F , but recently it alert
    And today ,I add victoria 8 into my content , it still alert "duplicate formulas found in files" when I load any G8F characters ,even a base G8F
    Even stranger,it's OK when I load G8M ,nothing wrong happened, and I'm quite sure I have not install any Michael 8 into my content, why...?
    1.I uninstall DAZ , and later install DAZ , but content is still there , problem is still .
    2.I uninstall DAZ , and later install DAZ , go to content manager ,clear all ,creat a new blank content , problem solved.
    3.After step 2 , everything is OK. And I copy a 【ContentDirectoryManager.dsx】back up into 【C:\Users\rika\AppData\Roaming\DAZ 3D\Studio4】, problem comes again !
    4.I clear content ,load 【Genesis 8 Female Starter Essentials】into content,add G8F from it to scene, it's OK
    but when I load my own document named【A】, add G8F from 【Genesis 8 Female Starter Essentials】 into scene ,problem comes.
    So, I guess it's a bug of content structuresad, my 【A】is broken ,it will confuse everything about G8F , and nothing concern about victoria 8
  • It means that either a) two products use the same name for a morph channel, and have links to a common channel, so that the links is duplicated as far as names are concerned or b) a single product has a doubled up link in itself. Uninstalling DS won't affect it, uninstalling the base Genesis 8 Female won't affect it - only removing the item causing the doubling up (or one of them if it's a clash between two items) will fix it - which is why I wanted you to find the log lines relating to the duplication.
