File not reading data path: HELP!
ShimuzuShimuzu Posts: 0
Hi all,
I need desperate help as I have a deadline for Friday.
My saved .duf file is not reading the data file path for some reason - any ideas how to fix this? It's loading up V6 as a block figure which is not good.
The only warning in the log is: WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(36): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
There is one custom ZBrush morph in the file and am wondering if this could be the cause of it. If so, is there any way to strip that morph out of the file using Text Wrangler?
Any help/ideas would be much appreciated, 7 works of work top salvage! Yikes.
  • fixmypcmikefixmypcmike Posts: 19,709
    What is the full path to your content folder, and what is the full path to the saved scene?
  • ShimuzuShimuzu Posts: 0
    Thanks for the swift reply. I've isolated the problem. it has to do with Goz and Zbrush Morphs. Saving a file containing a ZBrush morph corrupts the file for some reason. Managed to salvage 75% of work from a previous file. No ZBrush morphs for me until I find out what is causing the issue.
  • Richard HaseltineRichard Haseltine Posts: 109,523
    Which version of DS are you running? The bug you are seeing for fixed a while back, I thought both the beta and the production versions were now clear of it.
    Using 4.6.0.18, is that the latest?
    No, 4.6.1.33 is the current production build.
    Argh! Now Daz Studio Pro is not showing in my install manager - so can't even update! Lol. If its not one thing, its another! Thanks Richard.
  • DoctorJellybeanDoctorJellybean Posts: 9,797
    You could try the Product Library page on your account, it should show on that.
    Thanks it does, but there's only a link to download via Install Manager, and it just doesn't show - sort of a dead link. Everything else shows which is typical - just one of those days I guess. Have contacted support, hopefully this can be sorted soon.
  • KeryaKerya Posts: 10,943
    Are you sure you looked at the Product library of the Release version? The Beta is only available through DIM (I don't use DIM - don't ask) ...
    This is the General Release page
    http://www.daz3d.com/downloader/customer/files/#prod_13176
    Thanks, have tried that, its showing in my Products Library but not showing up in DIM - clicking on the download link does nothing at all. Have opened a support ticket but no response as yet. Will have to chase that up!
    Duh! Just realised that there is a button to download manually - kept thinking it was the manual/user guide to download!
    Great! Please remember you have to download the uppermost file "Default Lights and Shaders for DAZ Studio" too - before they were part of the Dazstudio install, now they are extra.
