How Combine surfaces / materials
onsteriononsterion Posts: 15
Hi All,
Had any way for combine the surfaces / materials? Because when export a FBX the result is in too many materials.
Example: Basic Wear Boxers with two surfaces / materials
Boxers surfaces / materials
Regards.-
Post edited by Chohole on
  • This can be done with the Geometry Editor tool. There you have all options to edit surfaces or face groups. Select some geometry and assign the selection to another surface. There is the right-click menu or the Tool Settings pane to acces the commands.
    Great! Thanks for the advice!
  • Syrus_Dante
    Thanks you , i searching multiple nights to find a way to reduce my Material while i try to fit the Cloth Simutaor on my Character in Unreal Engine , otherwise you cant Simulate with many Material Slots. cheers
