DS 4.6 Category drag and drop woes.
Does anyone have a work around for dragging and dropping same-name content folders from 'Unassigned' into 'Categories'?
I don't seem to be able to merge 2 folders with the same name.
Currently, I'm renaming one folder with an 'a' or whatever at the end of the folder name, so that it will copy, then merging the content manually from the Category view.
Also, I don't really see any benefit to the menu command 'Categorize' over simple dragging and dropping. Am I missing something?
(Sorry that the wording of this post is bonkers! I don't know how else to describe it.)
Thank you.
To get around that this is what I do. Open the content folder to be moved. Do a Select ALL on the content, then just drag and drop it instead of the folder.
After posting to your other thread Last night I decided to set my stuff up again. Boy this takes time.
