Is long render time normal for gtx 1080?
Hey guys,
Im a newbie to the 3d modeling world started it as a hobby going with daz. I want to know if I am doing this right or if there is something wrong. Plus does a computer restart help ? because i noticed that daz is faster after a restart.
Specs are : i7 7820hk, gtx 1080, 32 gb ram latest nvidia driver.
I just rendered a 4k image without any clothes (image is attached) and it took 1 hour and 20 minutes to complete the render. Is it a normal time for my specs? I feel something is wrong as these are not low specs.
  • That does sound a bit on the slow side for default settings, but is it just a figure in the open or is there an enclosure around it and were you using the deault settings (apart from size)?
  • Nope no enclosure around it just an open figure. I do not think they were default settings , umm if render settings change according to Genesis 8 figures then I guess since I loaded Daphne for olympia 8 the settings changed accordingly. I doubt they were default because when i set render settings tab to default setttings all the effects that makes the figure look better go away.
    Also, as a side note the eyebrows were Luxe Fibermesh. Every object was set to max personal resolution, sub d and render sub d.
