HD Genitals?
acanthisacanthis Posts: 604
edited January 2016 in The Commons
Post edited by acanthis on
  • SimonJMSimonJM Posts: 6,082
    I wouldn't hold your breath!
  • larsmidnattlarsmidnatt Posts: 4,511
    edited November 2013
    Considering how little detail they put into the lady loins I don't see how HD would help. They would need to make some morphs for it first...
    And honestly not sure if I'm gonna be that close to notice the difference really, but I could understand the need ;)
    Post edited by larsmidnatt on
  • TimbalesTimbales Posts: 2,432
    acanthis said:
    Well it's OK to ASK isn't it?
    (I realise that DAZ do not believe that human beings possess sexual organs until they are purchased from the local Biotech store, but if you do opt to have genitalia surgically grafted on then shouldn't they be made of the same basic genetic material? ;)
    for male gens, I suggest Jepe's M4 expansion set.
    As one who has seen that set, how in the world would one use it on G2M?
    With lube? ;)
    With lube? ;)
    *Facepalm*
    BAD Simon!
  • ByrdieByrdie Posts: 1,783
    I have found it's a wee bit tricky but it will work. Do NOT attempt to fit it to Genesis -- autofit will kill the thing deader than dead. You must parent it to the hip, then pose it and Genesis until you are satisfied with the results. Be aware that using an M4 genital prop works best with M4 textures on Genesis, last thing you need are skins that really don't match. It can be pretty embarrassing for the poor guy to try and explain why his junk is tanned but the rest of him is not. ;-)
    With lube? ;)
    You owe me a bottle water and some paper towels!
    *Facepalm*
    BAD Simon!
    Awww, c'mon - someone had to say it ... ;)
    It's best to load it into the scene before doing any character posing. Don't autofit to Gensis or G2M. Position it, apply a smoothing modifier with G or G2M as the parent, then parent it in place to G or G2M's hip.
    My most recent upload to deviantart is M6 with Jepe's Jonah textures using M4 gens with Jepe's expansion pack.
  • vwranglervwrangler Posts: 4,989
    Actually, it's not at all unusual for men to have genital skin that's noticeably darker than their body. The difficulty for these figures is that on an actual human, the color change is more or less continuous from lighter to darker (albeit happening in a relatively concentrated area), and with these props, it can be very abrupt. You want to try to match skin tone, of course, but going slightly darker if needed is probably fine.
    As a practical issue, I wonder if HD morphs and displacement would have to be made together for specific textures and specific ... er, body parts. Male genital textures, when they're not relatively basic, tend to have a lot of displacement, and it seems like heavy displacement combined with HD morphs might not go well together if they're not designed together.
    Any road, depending on how difficult or expensive it is for PAs to get the HD morphs SDK to work with, I expect the aftermarket will eventually provide.
    Whether you want it to or not.
  • MardookMardook Posts: 292
    I think its ok to ask.
    I would hope that the artists who make these HD genitals will make it available maybe not here but somewhere else.
  • Richard HaseltineRichard Haseltine Posts: 109,297
    You are aware that the figure is not HD, it's the morphs that are HD? So far the tools for making HD morphs are not generally available, so no one is in a position to make a product for sale elsewhere.
    Yep and okay then...
  • 3dLux3dLux Posts: 1,231
    SimonJM said:
    *Facepalm*
    BAD Simon!
    :lol:
    Great way to wake up! Thanks, Simon :cheese:
