Babina 8
12346»
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,832
    edited September 2019
    used power pose to create her expresion something new for me
    https://www.daz3d.com/gallery/#images/853621
    1289 x 2719 - 2M
    Post edited by ANGELREAPER1972 on
    There. Cleaned her teeth.
    I took out the Diffuse map with the brown teeth. I increased the Translucency Weight to add some color back to the teeth. (It uses the same brown tooth diffuse as the trans map.) I increased the Glossy weight...
    Forgot to switch to Low Translucency for the skin, though. Oops.
    What I usually do also is add a bit more specularity and gloss because teeth are a bit wet as are gums which are often not done right by creators as well. But the other issue is, all her teeth are the same size! I have a morph package that can fix that but I shouldn’t have to. I’ve never seen teeth like piano keys like this, all the same size.,,And her mouth seems to behave like some of the G3 characters, the sides not pulling out into a natural smile.
    I might have purchased the bundle if it had come with freebies like all other past pro bundles, but I think I’m going to pass for now.
    https://www.daz3d.com/gallery/#images/o
    That looks good! Much better than the promos. What lingerie and hair is that? (Never mind, found it in your gallery!)
    Post edited by Wonderland on
  • Anyone know what hair this is in this promo image for Babina?
  • TaozTaoz Posts: 10,356
    Might be this:
    https://www.daz3d.com/untamed-curls-hair-for-genesis-3-and-8-females
    Wow, that's an excellent job! And Babina herself seems a subtle step up to prior Pro Bundle models.
    Cute joke. They are so white and bright you can't even see the gaps between the teeth but that's accurate for some actors & actresses. It looks like she's wearing a mouthpiece for Halloween or something. Did you turn on the emissive light setting on the teeth?  The inside of her mouth should not have more light than the outside. laugh
  • nicsttnicstt Posts: 11,715
    Series of CDI Babina expressions plus 1 Kala 8 Mixable (Seducing).
    Nothing fancy.
    I prefer the mixable-style expressions rather than posed full faces.
    Thanks for showing her with different expressions. laugh Your renders are great but poor Babina really needs to see a dentist lol. What’s with the yellow dirty teeth? And all the teeth look the same size...  I think this one will be relagated to waiting for when a better sale comes along. I never use a character as is anyway, but this would just be extra work fixing those teeth!
    And this reminds me. There is a certain PA who makes the most stunning characters—as long as their mouth is closed. The minute I add a smile, I have to correct the surfaces on the teeth which looks like the teeth of an 80 year-old and even use the Y axis to move either the top or bottom teeth. I wish creators would check their characters with several expressions.
    Actually human beings teeth are naturally shades of grey-yellow as that's the natural color of the mineral compounds from which they are made. The Pantone RGB (0,0,0) white teeth of modern Hollywood look totally unnatural. In fact, sometimes when I am watching old TV series and old movies and I see healthy but non-plastic teeth in the actors mouths I can't help but smile about it. So I will keep smiling and showing those yellow teeth regardless and even characters in fictional renders should too.
    +1
    White is annoying.
    That's buying the coolaid from the companies that sell related products.
    Her teeth looked real before, now they don't.
  • 3Diva3Diva Posts: 12,058
    Babina 8 with some skin, teeth, and eye settings adjustments with Altern8 and additional manual surfaces adjustments. Light post work for color and brightness.
    1000 x 1300 - 2M
    1000 x 1300 - 2M
    Post edited by 3Diva on
    Her teeth looked real if she's a heavy smoker and drinks coffee/tea all day.
    It's not my kind of look, but that's subjective.
    So you didn't turn on emissive? Even the phosphors they put in eyedrops & toothpastes only last about 15 minutes before the bright white effect they show the user in the mirror while they are brushing fades away.
  • Siciliano1969Siciliano1969 Posts: 433
    I love Babina!
    1485 x 1794 - 209K
    Post edited by Siciliano1969 on
  • xyer0xyer0 Posts: 6,510
    Polish Girls Rule
    1600 x 1500 - 4M
    Post edited by xyer0 on
  • memcneil70memcneil70 Posts: 6,126
    All the renders have been wonderful and enlightning.
    I want to say to Divamakeup that those two latest renders remind me of the spirit of my younger sister in the 1970s on the coast of California. Her hair was waist length and loose, but still multiple shades of blond and a free spirit. Thank you for reminding me of a wonderful memory.
    Mary
    Mary
    Awww I'm glad my renders reminded you of your younger sister and a good memory with her. Thanks for the lovely comment, Mary. smiley
  • thank you nonesuch00 and  Wonderland, the lighting I used helped
    Lady Babina
    1600 x 1500 - 5M
  • barbultbarbult Posts: 27,549
    xyer0 said:
    Lady Babina
    Nice!!
    3840 x 2160 - 8M
  • sapatsapat Posts: 1,735
    sapat said:
    sapat said:
    SBibb said:
    sapat said:
    sapat said:
    I might be blind, but where i the original outfit for these textures?
    https://www.daz3d.com/dforce-boho-days-outfit-textures_OziChick
    I'm worried that the base outfit won't be released today before the 20% off coupon expires.  I want the textures, but need the outfit.  If it happens the they don't get it in the store before the coupon exprires, how will we stilll get the 20% off? Someone has already put in a ticket, but should more of use do it? Or will Daz say 'oops sorry too bad'.
    How we make a ticket for something like this? Where do you go?
    crying
    Click "Help" at the top of the bar and click "Contact Us" on the next page that opens, and then click "Submit ticket."
    That's where you would go to submit the request. I'm not sure if you'll need to take a screenshot of your cart or your coupon, or what they'll want in specific, but I'd go ahead and submit the request. I don't know if they'll be willing to give you the discount later, but they have responded in the past to when there was a mistake on the sale with an option to pick something up, so there's a chance they might.
    Good luck with that.
    That's where i went but it looks like the regular think
    I filed a ticket with a screenshot of my banner. I didn't put anything in my cart since I was waiting for the outfit to show up.
    had a reply yet? Been a few days now. Still no sign of that outfit as far as I've noticed but I've been getting purple banners everyday for 20% off different codes but still same deal so maybe go all through sale if your lucky then of course it may not be released during this sale too
    I finally got a reply. They said that it was their fault that the textures were added before the outfit, and they will be released 'in the future'.  So whatever point in time they consider the future. They said 'sorry, we can't give you the textures since the outfit isn't in the store.'
    can't give you the textures since the outfit isn't in the store yet - love that answer - they better offer a good deal when it is probably be months ain't the first time it's happened
    Right?  We'll see....if we even remember to look by then.
    Thanks @barbult for the comment. You guys have posted some fabulous renders! I wanted to show Babina 8's mugshot in Daz default with headlamp (which I do for all characters as my quick reference audition folder). Her skin is great, but I don't care for the identical symmetrical cheek blemishes.
    1140 x 1600 - 3M
  • thanks XpiderMan
    turned Babina into a human dinosaur hybrid
    https://www.daz3d.com/gallery/#images/857921
    2719 x 1289 - 3M
  • vl80s2012vl80s2012 Posts: 27
    edited May 2020
    Hello, dear colleagues in the forum! Please tell me, what morphs are applied to the head of the babina in these images? https://www.daz3d.com/media/catalog/product/cache/1/image/960x1248/17f82f742ffe127f42dca9de82fb58b1/b/a/babina-8-00-main-daz3d.jpg https://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/r/a/raver-hair-for-genesis-8-females-00-main-daz3d_1.jpg https://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/r/a/raver-hair-for-genesis-8-females-03-daz3d.jpg https://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/r/a/raver-hair-for-genesis-8-females-04-daz3d.jpg I searched for this morph for a long time, but I just can’t find it. Very pretty. The base model has a too angular face, it looks older. On those morphs, the face has a less pointed chin, another incision in the eyes, and a smoother face shape. https://www.daz3d.com/forums/uploads/FileUpload/b4/b18723308c6f4c31ba5fc0cc3528db.png If you help me find these facial morphs, I will be very grateful for your help.
    Post edited by vl80s2012 on
    I apologize for the errors in the text, I am from Russia, I am writing through a translator.
  • ArtiniArtini Posts: 10,909
    edited January 2021
    Still, one of my favorites characters of Genesis 8 generation.
    2048 x 2048 - 1M
    Post edited by Artini on
