How can I convert DSON Support files into DSON User files?
Poser 2012 can read DSON User files only, and I have M5 but in DSON Support file type, how can I change it into DSON User file in order to my poser can load it? thank you.
I don't understand your question. M5 works in Poser 2012 just fine without converting one kind if DUF file to another.
it loads, but textures, poses, etc. can't be read. I noticed because they are in DSON Suport file (in orange) and the files poser can read are in DSON User files (in blue)
You have to install poser companion files in poser. Go to your account/ Product library
Are you loading them through their links in the Poser Library?
Yes, but let me check your previous answer, but it is what I'm making wrong.
If you have .dsf files in \Runtime\Libraries\Character\whatever then download again and reinstall. The current version should use .duf (though PoserCFs imply .duf so I'm a little puzzled by the whole situation and wonder if you are placing the wrong fiels in the wrong place).
Go to Dimension 3D's website. Under software and Poser tools you will find the DSON loader. Install this script to the same Poser Python runtime that the rest of D3D's scripts are in.
This script will read DSON and load them in Poser without the need for Poser Companion Files. Depending upon the product, you may need to tweak or even do your own textures for products if they use DS Shadermixer. Poser and DS have different material rooms due to the differences in their render engines.
If you are using V5 or M5, Mec4D has a DSON UV script that allows you to change UV's from the default V4 to M4, V5 and M5. To date she has not updated the script beyond those UV's. It was offered free here at DAZ. She does charge a nominal fee for it in her store to cover bandwidth charges.
You could just save new character or wardrobe presets, which would then be .duf files, and create Poser companion Files for those.
