When does DAZ treat an object as a cloth that moves along?
Hello!
I have imported a jacket OBJ.
I think I did everything to "tell" DAZ that it's a cloth that should conform and move along with the model.
I have used the Transfer Utility, and I have parented the jacket to the model, and I have clicked "Fit to...".
However, when I move an arm of my Genesis 2 Female model, the jacket doesn't move.
Instead, the jacket stays just perfectly where it is and also doesn't conform along with the arm.
What else could I check?
What were your settings in the Transfer Utility? Does the jacket line up with the figure when both are zeroed?
I found the culprit:
My Genesis 2 Female had a full body morph applied.
In the Transfer Utility, I didn't select anything special.
Only after I selected "Current" for "Genesis 2 Female", the cloth would move along with the body.
