dForce Nightmare
DDCreateDDCreate Posts: 1,416
What in the world is happening here? I checked deleted and re-added the only dForce Weight Node to the uniform top but it insists on dForming the character too. This looks like something out of Stranger Things which would be cool if that's what I was going for but it kinda isn't. Does anyone know what's causing this?
    That's very cool=)) You should save as a morph for future uselaugh. I've no idea what's happening,what if you unparent the clothing before running the sim?
  • scorpioscorpio Posts: 8,533
    Is it possible that you have added a dforce to the figure as well as the garment.
  • FenixPhoenixFenixPhoenix Posts: 3,185
    edited August 2019
    Like Scorpio mentioned, that happened to me once when I mistakenly added a dforce modifier to the figure instead of the wardrobe.
    To remove them:
    1. Select the figure.
    2. Open the Simmulation setting pane. Open the hamburger menu then dforce > Remove dforce modifier. OR go to Edit > Figure > Geometry > Remove dforce modifier.
    Post edited by FenixPhoenix on
  • DDCreateDDCreate Posts: 1,416
    I thought that's what it was too but when I searched for the dForce node in the Scene Pane it only found the one that was applied to the top. Weird. Might have just been a glitch. The clothing isn't built for dForce in the first place to maybe it's just a little hiccup. Seems to have righted it self.
