Daz Model - Export Help
I've making a custom morph in Daz 4.11. I've used the Joan preset for Vic 8 as a starting point and completely customized the avatar. For some reason this avatar doesn't want to import to any software. I've gone and tested both default and morphed versions of Vic 8 and the Joan preset with Marvelous Designer, and they import with no issue. The only differences with my custom avatar is that there's the Teena hair and a RenderCam in the sceen.
I'm using all the same import/export settings from the same location on my PC. Any ideas?
  • What are you trying to do? You can't edit to create morphs if there are additional items in the file.
    I'm trying to export a customized Daz avatar to C4D, Marvelous Designer, Zbrush etc.
  • Turns out the hair was the problem, when I deleted the hair the export worked.
