Does Horror Movie Patient for Genesis work well with G8F?
SBibbSBibb Posts: 600
I'm looking for a hospital gown to use for a character on a book cover, and I was wondering if Horror Movie Patient for Genesis worked okay on Genesis 8 Female characters? ( https://www.daz3d.com/Horror-movie-patient-for-genesis ) -- In particular, the blue outfit in the promo that laces up in the back?
If so, does it work well with DForce added? (That one isn't a requirement, but would definitely make it more feasible for looking right).
I'd love to see examples, if anyone has any. Doesn't need to be anything complicated, just seeing if it can fit a Genesis 8 female character. :-)
(Or if you know of a hospital gown like that one available in the store for Genesis 3 or 8 that I'm just not finding, please let me know).
  • TaozTaoz Posts: 10,269
    edited August 2019
    The different pieces autofit quite well on their own, but there may be some poke through and distortion when combining some of them, especially if you use the briefs. Maybe some of the tools out there can fix it.
    Have very little experience with dForce but I'm giving it a try with the gown to see how it works out.
    929 x 950 - 708K
    929 x 950 - 640K
    Post edited by Taoz on
    Didn't work out well with dForce, first time the gown simply disappeared, second time DS (4.12) crashed.  Probably my lack of experience that is the problem.  Maybe someone else can make it work?
  • HavosHavos Posts: 5,594
    edited August 2019
    There is this one for G3.
    https://www.daz3d.com/hospital-wear-for-genesis-3-male-s-and-female-s
    It autofitted alright to G8F, but the bottom of the gown is then glued to the thighs, and so looks bad with any significant leg movement. On G3F it naturally works better, and there is some movement morphs to help with the draping. It is not suitable for dForce, as it has almost 300K polys, and my one attempt to simulate this blew up. Here is a render on G3F, without dForce.
    Another option is this freebie. It is for V4, but is dynamic, so should work with the newer figures with a bit of work. It works fine dynamically.
    http://www.optitex-dynamiccloth.com/FreebieDownload08.php
    I used it in the render below, I think the figure was G8F, but it might have been G3F. dForce was used.
    1024 x 1024 - 1M
    1024 x 1024 - 63K
    Post edited by Havos on
  • SBibbSBibb Posts: 600
    Thanks for the render examples @Taoz and @Havos. And thanks for testing and reporting on DForce results, too. I really appreciate it. :-D
    At the moment I think I'm leaning toward the Genesis 3 outfit since it looks like it might be easier to make it look natural, but I'm liking how the pajamas look on the Genesis outfit set. I'm going to think on it a bit more, but this gives me a pair of options.
    Thanks again!
