Anagenessis for Genesis 3
DivaDolly
in The Commons
Can anybody tell me what Ive done wrong?
It renders OK I think but why does this happen when I apply the material to Victoria 7
I will be extremely grateful for some help to resolve this issue
Thank you :)
I don't own the genesis 3 version but I guess that you had surfaces selected while applying the script?
Thank you I'll check that out ????
You can also get artifacts like that in preview if there is opacity in the settings you are applying so that is something else to look for
+1
The character doesn't have the usual look that NGS have, but that may be because you're using v1 and not v2; i use v2 all the time.
Thanks for all your suggestions guys, really appreciate your help and hopefully will be able to resolve this issue
I'm curious, how did you apply the Anagenesis shader to the character?
There is something going wrong.
I loaded V8; applied Agenesis 2 shader (I don't have the original). I could have loaded V7 as works fine using the G3 shader option, I'm not sure if Agenesis will also work on G8.
if you look in the second image at the horizontal and vertical tiles, you'll see tiling set to 1; they should be the same on your figure, and if not, are you using the correct shader option? It doesn't seem to matter with Agenesis 2, but may with what you're using.
If you can't sort it out, I raise a help ticket with Daz..
Thank you so much for your help and im still not able to resolve issue so as you've suggested, i'm going to submit a support ticket to DAZ
