How do you shape text to wrap around cylinder?
Jan_Scrapper
I needed some text in Poser that wraps around the bottom of a carosel in place of the textured map I am using.
I wrote the word AMUSEMENT in Carrara. Now, I need to bend the sides to wrap around a base. I used the bend/twist modifier, however I couldn't get it bent
the proper way.
Would someone please help? Thank you so much!!
the following settings may help you achieve to bend it
Thank you!!! That is exactly what I needed!! Perfect :)
awesome
