How can i change the textures folder?
I'd live to change the folder of the textures of my content library cause they're taking too much space in my main HD, is there any way i could do that?
Thanks in advance.
Thanks in advance.
Create a new content directory on another drive, add it to DS (you can do that by right-click on Daz Studio Formats and/or Poser Formats in the Content Library pane), and move the /Runtime/Textures folder to that. Are you going to continue to isntall to the existing folder for new stuff, or do you want to move everything?
i'd like to move everything there =)
In that case just move the whole content directory across, and point DS to it as above (you can also right-click on the old directories to remove them). Assuming you can see your moved content in DS, download this script (there's a link above the code), drag it into the DS Viewport (with Install Manager closed) and that should update DIM for future installs.
