Trying to make long legged woman (Answered)
RychardesRealmRychardesRealm Posts: 61
edited August 2019 in The Commons
Did a bit of research on long-legged women, not getting percentages and such on the length which was what I was looking for, but I got a rough idea of what I need to do for stretching and crunching in an intuitive fashion.
Now the problem, how do I lengthen the legs and crunch the upper torso since there are no scales for x, y, and z only? Using the scale available gives an awful look showing signs of major genetic issues.
The proportions I'm shooting for are D > C and B > A.
Now that I have lost you in my very crude attempts describing my problem (it has been a long night), maybe a look at an article I got these pix from, they detail what I have mangled: Vertical body proportions.
Here's hoping the solution is a fairly simple one. wink
Post edited by RychardesRealm on
  • FSMCDesignsFSMCDesigns Posts: 12,844
    use the DAZ body morphs. Under legs there is a leg lengthen and under waist there is a torso lengthen with plus and minus values.
  • mr clammr clam Posts: 707
    To clarify:
    Michael's referring to this or a similar product (there are differnt versions for each generation) https://www.daz3d.com/genesis-8-female-body-morphs
    Also included in this set is a height morph, which may also be of use.
  • Cool, and I have the body morphs. A LONG day before I started to research. A LONGER day afterward and would miss the obvious solution (as I did) if there was a huge sign pointing where I should look. <sigh> ;)
  • Bunyip02Bunyip02 Posts: 9,251
    edited August 2019
    Some of the earlier figures also had some lengthen morphs
    1479 x 994 - 304K
    Post edited by Bunyip02 on
