What is the Lost and Found category in Smart Content?
Hello,
I was wondering what exactly is the Lost and Found Category in the far left hand column of the Smart Content window? I have noticed that a lot of items that I have installed using the DIM show up there for some reason and they are often grayed out, but they still load when I double click on them.
Thanks in advance to anyone who replies.
nabob21
  • TSasha SmithTSasha Smith Posts: 27,432
    I think it is something that was not categorized right but I am not on my computer right now.
  • nabob21nabob21 Posts: 1,057
    Thank you for the reply Miss Bad Wolf. If what your saying is correct that is very strange because even brand new items I downloaded and installed are showing up in there, and you would think that they should be categorized correctly.
  • NorthOf45NorthOf45 Posts: 5,760
    The categorization and compatibility is only as good as the metadata. If the metadata is wrong or missing (i.e., wrong path, wrong filename, does not define a default category, does not define a content type, among other things) then it falls into Lost and Found.
    Thank you NorthOf45
