Animate 2
alerender_ce6728e4fe
Hi, I need help. In Animate2 I cannot open the menu below on the left. I do not see the side scroll bar
Looks like you've either no aniBlocks installed or your Preferences path to DAZ Content Library is configured incorrectly, one of the two.
Well not sure but you can try and go to menu:
a) Window -> Workspace -> Customize - Defaults
and then exit and start DAZ Studio
I know that in my DAZ Studio if I make some sub-panes too large or too small I loose the ability to scroll in them. This seem to be a problem with QT GUI that DAZ Studio uses that QT should be allowing.
Edit -> Preferences...(F2)
then Content tab
then Content Directory manager... button
expand the +DAZ Studio Formats content set
make sure that you have your My Library and or any My DAZ 3D Library or other folder where you store your DAZ studio files.
i.e. the folder under which you have your aniBlocks folder.
To add folder select the +DAZ Studio Formats content sets header then clcik the Directory: Add... button.
Also in aniMate2 -> Preferences, I prefer to have the Create scripts for aniBlocks at startup: ticked.
