Animate 2
Hi, I need help. In Animate2 I cannot open the menu below on the left. I do not see the side scroll bar
  • nonesuch00nonesuch00 Posts: 18,744
    Looks like you've either no aniBlocks installed or your Preferences path to DAZ Content Library is configured incorrectly, one of the two.
  • I have the aniblocks .. but I can't scroll up in that menu
    Well not sure but you can try and go to menu:
    a) Window -> Workspace -> Customize - Defaults
    and then exit and start DAZ Studio
    I know that in my DAZ Studio if I make some sub-panes too large or too small I loose the ability to scroll in them. This seem to be a problem with QT GUI that DAZ Studio uses that QT should be allowing.
  • I could not fix it. but thanks for the reply
  • surrealsurreal Posts: 198
    Edit -> Preferences...(F2)
    then Content tab
    then Content Directory manager... button
    expand the +DAZ Studio Formats content set
    make sure that you have your My Library and or any My DAZ 3D Library or other folder where you store your DAZ studio files.
    i.e. the folder under which you have your aniBlocks folder.
    To add folder select the +DAZ Studio Formats content sets header then clcik the Directory: Add... button.
    Also in aniMate2 -> Preferences, I prefer to have the Create scripts for aniBlocks at startup: ticked.
