Want to create a city with no building perspective
Hello, I want to make a City Map render that will be transferred to another program so I can scroll through the map in a zoomed in view. So it won't be a complete view. So when a person scrolls through the map and on the left side the buildings are tilted left and the right side the buildings are tilted right it doesn't look right since it is not a complete aerial view since it is zoomed in. Is there any way to make the whole map look like as if it was from the center of the camera with no perspective? I am using a camera with a 15 degree tilt to get a nice aerial look not a complete top view. I still want the persepctive look from the center but I don't want the flat look of non-perspective.
Post edited by AnonTurtle on
Try turning off Perspective in the camera's properties.
in viewports you have "top view"
I'd suggest playing a bit with the position (or distance) of your camera and the focal length of your camera. A low focal length with a low positioned camera can give a bit of a wide-angle birds-eye view, while a high positioned camera with a high focal length will result in something more similar to a zoomed image from a satellite.
