Victoria 4.2 Creature Creator Morphs
ArisguardArisguard Posts: 122
Hi, i have purchase this product but the morf don't is applicated. Why? i have victoria 4.2 base installated
  • Richard HaseltineRichard Haseltine Posts: 108,412
    Poser or DAZ Studio? Did you install to the same content location as the base Victoria 4? If DAZ Studio, are you using the Power Loader tool (do you get a dialogue when you load V4)? Note that new morphs won't be added to saved figures, only to newly loaded figures.
    Well, I assume DS since you isntalled to a DS forum - however the SDK forum is for the SDK (plug-in making) rather than for general issues.
  • ArisguardArisguard Posts: 122
    I used DAZ Install Manager for install the product
    for daz studio
    If DAZ Studio, are you using the Power Loader tool (do you get a dialogue when you load V4)? yes i have a dialogue whem load V4
    V4 is in content library -> Poser formats
    Please post a screenshot of what you see in Power Loader when loading V4.
    He1re it is1
    1920 x 1080 - 538K
    OK, if you right-click on the Victoria 4.2 icon in Smart Content and choose Show in Content Library it will open the folder in the Content Library that holds the figure files - is that in the content directory you installed the morphs to? If it isn't clear, right-click on the icon in the Content Library and from the menu choose Browse to file location... - that will open a window showing the actual file on disc, and you will be able to see the full path from that - the path up to the Runtime folder should be the path you installed the morphs to.
    This path is correct? C:\Users\Samuele\Documents\DAZ 3D\Studio\My Library\Runtime\Libraries\!DAZ\Victoria 4\Deltas\Creature
  • BejaymacBejaymac Posts: 1,946
    Sounds like DUM hasn't run the updater to add the morph channels to V4's EXP system.
    I don't know - it isn't obviously wrong, but where is the Victoria 4.2.cr2 file you are opening?
    ok I solved, finally I have the morph
