Dform Tool, What Next?
david_23523141
Hi All,
Thanks in advance for any tips and suggestions. Question, when a new Dform is created on an object and then the base is moved into position making the satisfactory Dform, is there any action needed to apply or bake, for a lack of better word, the Dform permanently. Said, another way, once the Dform is made and looks good, does the Dform just sit there in the Dform tab never to be touched again. There is no "apply" button and I assume deleting it after the base is moved would delete the adjustment as well, so I"m inclined to think that after the Dform is applied, one just let's it sit there in the hiearchy as a sort of permanent tag applied to the object.
Thank you
You have to select the object/figure to which the dFormer is applied. Then open the dFormer pane and "spawn to morph". The morph will be added to the parameters pane/morphs. After that you can delete the dFormer and dial in the morph instead.
Fantastic
