How come DS 4.6 does not install to program files?
UVDanUVDan Posts: 112
edited November 2013 in Daz Studio Discussion
I downloaded DS4.6 pro this morning and I cannot find it anywhere in my start menu even though the content manager tells me that it is installed. So how can I run it if I cannot even find it?
Can somebody tell me where it launches from? How come the content manager does not put icons on my desktop to launch it with?
Post edited by UVDan on
  • ShelLuserShelLuser Posts: 749
    A very important detail is how you installed it?
    Did you start by installing the install manager and then used that tool to get Daz Studio, or did you grab a separate installer?
    Also; what does Windows tell you when you go over the list of installed programs?
  • UVDanUVDan Posts: 112
    Yes I did use the install manager and installed DS4.6 pro in that application. There is no DS4.6 in my installed programs anywhere.
    I FOUND IT FINALLY!!! It was installed to the Download Manager folder under shared documents. So now I cannot find an uninstaller for it so I can put it where I want it. I have searched under the control panel add and remove programs and it is not there. So I appear to be hosed as far as uninstalling it from the Content Manager folder so I can install it to Program Files.
    Why does it not install to Program Files where every other program gets installed to?
    It should. C:\Program Files is the default location for executable contents which you install through the install manager. That is; when talking about the 32bit software. It is possible that this differs on 64 bit. Especially if you happen to download & install 32bit software on a 64bit environment.
    Alas; after you started the install manager (logging on is optional) you'll find a "cog icon" in the upper right corner. Click it. Now you'll get a new window which has 4 tabs: "Accounts, Downloads, Installation and Applications".
    Click on Installation. Here you can set the default location for installed contents. As said, on my end it was set to "c:\program files" at first, I quickly changed this to use drive D.
    But after that it should work as you expect. Daz Studio uses a regular installer which will also create a start menu entry and such.
    I've attached some screenshots to show you what I mean.
    551 x 516 - 38K
    429 x 587 - 45K
    Post edited by ShelLuser on
  • fixmypcmikefixmypcmike Posts: 19,708
    Uninstall it with DIM, then make sure the Applications tab has the correct settings for installing 32-bit and 64-bit applications.
  • JaderailJaderail Posts: 0
    Your DIM Applications should POINT to your install paths like this...
    683 x 539 - 70K
    I had to manually update the DIM. I had the old version. The new version has the correct install path for DS 4 Pro. Thanks everyone.
