speeding up a section of an animation Keyframe
Hi all....
Ok... take a look at this attached gif file.![]()
As you can see tha anim is using keyframes (between two poses). What I want to know is..... HOW do I make the "Kick" section faster??
Daz does a ver nice smooth translation between the two poses...thats great... but how do I (Or what do I) do on the time line to make the kick part faster and not as smooth.
Thanks! :-)
Your gif is not working (at least not for me)
To make is faster - you would move the 2nd keyframe closer (e.g. if you are using poses, and pose #1 is on frame zero, pose #2 is on frame ten , move pose #2 closer to , say frame five)
To make it "not as smooth" - you'd have to adjust other bones, instead of letting DS interpolate between keyframes . A "real" kick has more complex body motion; you can't use 2 poses and interpolate between them
Ok pdr0 I will give it a go. Thanks for your info. :)
