Grainy-ness of lighting settings
inthanityinthanity Posts: 89
See the image below. What dictates the grainy appearance of the lighting/shadowing of uberenvironment lighting, etc.? I want to maintain the level of illumination and the shadow effects as seen here, but eliminate - or minimize - the grainy light/shadow imprinting on the figure. Is this simply the nature of uberenvironment lighting?
Any help is appreciated.
  • frank0314frank0314 Posts: 14,765
    What are your render settings? Your shading rate should be about .2 or .1
  • RiggswolfeRiggswolfe Posts: 914
    Go to your UE folder and apply one of the quality settings. It defaults to a low quality but fast version of the shader. I think the main setting you are looking for in UE parameters is called Shading Rate or something like that. (I haven't used UE in awhile)
  • inthanityinthanity Posts: 89
    Attached is one section of the light settings for the render. The Shading Rate is at 0.5.
    390 x 416 - 23K
  • JaderailJaderail Posts: 0
    This is UberE set to the HIGH setting using the Set Quality to 4x icon...
    493 x 618 - 32K
    Then in your Render Settings you set Shading rate to .5 or .2 as in this...
    328 x 517 - 21K
  • Richard HaseltineRichard Haseltine Posts: 109,303
    Given that you have soft shadows you may also need to increase the Shadow Samples setting.
