Cut a hairstyle to make it shorter?
I bought Layered Fringe Hair (SKU 56271) because I really like how it looks from the neck up. The only issue I have is with the length of the hair. Unfortunately, the morph sliders for this hairstyle don't allow me to shorten the hair very much.
I've looked at shorter prefab hairstyles, and none of them have the look I want above the neck, so my only option is to take this long hairstyle and cut off everything below the neck. Does anyone know how I can do this and make it look half-decent?
  • fastbike1fastbike1 Posts: 4,079
    Try unlocking Limits on the Sliders.
  • I've tried that too. The hair does not scrunch up, but instead sticks out in bizarre directions.
  • chris-2599934chris-2599934 Posts: 1,908
    You could use the geometry editor to hide the longer parts of the hair, but the end result is unlikely to bear close scrutiny.
    The only other alternative I can think of is that you do two shots - one with the hair at normal length, and one with no hair at all, then edit them together in post to get the effect you want.
  • edited August 2019
    That was my first thought, and I had the same misgivings about it. Maybe if I also edit the texture files it could work...
    EDIT: It does not work. The same parts of the texture file are used across different regions of the hair mesh, so it's impossible to make the long hair in back invisible without also affecting areas higher up.
    I'm not sure photoshopping two renders together would hold up under scrutiny either. Besides that, I plan to make a work consisting of a lengthy series of renders, and I'm not sure I have the patience to go through that process for every single one that this character is in.
    Post edited by Questionable Sanity on
    @Questionable Sanity "I'm not sure photoshopping two renders together would hold up under scrutiny either. Besides that, I plan to make a work consisting of a lengthy series of renders, and I'm not sure I have the patience to go through that process for every single one that this character is in."
    The you answer is find a different hair that looks like you want.
  • LeanaLeana Posts: 12,834
    You can always try creating a morph for the hair yourself.
    I don't understand what that means, but I'm interested to hear more. I always prefer to frontload the work rather than fix it in post, whenever possible.
    edited August 2019
    I don't have that hair but depending on how the material zones are setup you may be able to get around that by creating multiple transmaps for the different surfaces, or using LIE to alter the transmap on some surfaces.
    You would need to bring the hair in a modeller and alter it, then import the modified mesh as a morph with Morph Loader Pro. You could use the Hexagon bridge for that for example.
    You can't remove any part of the mesh if you want it to work as a morph, only move the vertices, so it wouldn't be that easy, especially since that hair seems to have a lot of strands. But it's probably doable.
    Post edited by Leana on
  • Holy crap, I just tried the Geometry Editor on the hair in earnest, and I'm already impressed by the results! By lasso-selecting and hiding polygons, I can cut away any part of the hair I don't like. And if it looks a little too short, I can just invert which polygons are hidden, select the ones I want to add back on, then invert again to see the results.
    This is only a first pass, and the bottom of the hair still has obvious polygonal jank, but just this amount of progress has given me a new surge of optimism. Plus, since I'm only hiding polygons and not deleting them, I can tweak the hidden polygons each time I shoot from an angle that doesn't look so great.
    Yeah, I've already discovered that outright deleting portions of the hair mesh screws up the texture mapping. I guess that means merging vertices is out too.
    Maybe if I pinch down the new ends of the strands into points, without actually merging the vertices, I can get a good result.
    400 x 400 - 148K
