Duplicate Formulas Found Error for Genesis 8 Male and Female
amalliach_858df2e8amalliach_858df2e8 Posts: 47
edited August 2019 in The Commons
Hello!
I have a problem with the "Duplicate forumlas found", for Genesis 8 Male and Female. I tried to solve this problem from https://www.daz3d.com/forums/discussion/271331/dazstudio-4-10-duplicate-formula-error-for-genesis-8-female and https://www.daz3d.com/forums/discussion/22220/duplicate-formulas-error-solved-thank-you-bejaymac but I can't seem to understand how to fix this. Not sure what do I have to install or to unninstall or to update..
I am attaching the log file, which is huuuuuge, with this kind of text. I am truly lost. I get this message everytime I open a new Gen 8 male/female character.
Please, can anyone helpe me with this? :( Thank you so much for your time!
Post edited by amalliach_858df2e8 on
  • Valery3DValery3D Posts: 105
    Hello!
    Is it possible that you imstalled both figures twice
    in different directories ? Maybe once through connect
    and the second one manually installed or through the
    install manager?
  • The list of properties not found is not an error, usually, and can be ignored. The actual duplicate forumlae are related to LY Briallen - make sure you have the current version of the character as it was recently updated. (Dueplicate formulae are in the morph asset files and those are read every time you load the base figure.)
    Yes those duplicate formulae are indeed in the morph files the reason why i suggest for them to check if they have the figures double installed is because i had this happend while working on a project while the product was double installed on two different places and folders and therefor it had two times the same morphs files but in different Paths and directories. If they Will uninstall one of the products then the error Will be gone because that way you also remove the double morphs folder.  I thought it might be happening in this case too you never know and this would be simple and easy to solve ????
    Sorry about the question Marks they were supose to be a smiley face but it got turned into question Marks somehow lol.
  • Solved!! thank you so much!
    I re installed the Ly Briallen figure, and everything works fine! Tahnk you so much!!
  • Yeah I had a similar issue. Rectified it by deleting the morphs and character that were causing the duplicate error. Haven't bothered to install that particular character again though as I probably won't use it as much anyway. Restarted Daz Studio and Gen8M now loads fine without errors.
