Issue with Genesis 8 Female anatomical elements *SOLVED*
VisuimagVisuimag Posts: 578
edited July 2019 in The Commons
I seem to be having an issue with anatomical elements. The first one I did today went fine, but now, anytime I add them to the figure (Genesis 8 Female - specifically an existing one and not the default), the textures won't show in the viewport. The surfaces are in place, but the elements remain white/gray. I've done everything needed, including making sure hierarchies are met.
Any advice is much appreciated.
Post edited by Visuimag on
  • VisuimagVisuimag Posts: 578
    Update: My apologies. Simple fix was that I had a GeoShell in the way. Sorry for the needless thread and, if a mod kindly would, lock this one up!
  • I got the same issue, can you tell me exactly what you did? what is  shell?
