Opening Content in Studio, Receive Missing Files Error Notification--SOLVED
Hi all,
I've recently had an issue pop up with Studio. I've purchased and downloaded a lot of content from Daz, but recently, I purchased an environment item, and today, when I started building my scene, when I attempted to select the item from my content library, I received an error that said required files were missing. The content then loaded as blocks. I've attached screenshots of the error messages as well as my program files, as I followed the path to my C/Users/Public/Public Documents/Program Files/My Daz 3D Library/Environments...et cetera...and it appears the files installed through DIM to the correct location.
Any thoughts or suggestions?
Thank you,
Jason
Post edited by sartechfairweather on
Morning!
To be able to use the Neglected Loft you need to have A Bright Loft installed to the same location. From the images you showed it looks like all you have installed is the Neglected Loft.
Elli
Perfect! I wasn't paying enough attention when I purchased it. I went back, purchased, downloaded, and installed that content, and it works perfectly! You were right-on! :)
Thank you very much for taking the time to look this over and help out! :)
Jason
