Timeline Vanished?
DekeDeke Posts: 1,636
So I was animated in the time line and thought I'd shift to the Animate Lite tab. When I switched back to Timeline all the setting there were gone. It shortened the sequence to 30 frames and erased all the keyframes. Is that supposed to happen?
  • JaderailJaderail Posts: 0
    The proper way is AniMate2 First then SEND TO Timeline then Work on the Timeline. The other way as you see just does not work.
    But you Could Import from Timeline and SAVE as AniBlock if you have the Full AniMate2.
  • DekeDeke Posts: 1,636
    Thanks....so all that information is lost? That's a real glitch in the system. Live and learn.
