Grey bounding boxes around models during every action
Not sure if I should have put this here or new users. Been using Daz about 2 weeks, and all of a sudden there are grey bounding boxes around every model anytime you perform any actions. Move the model, move a slider, you name it. Any idea what could have changed? I tried the find an answer on my own, but had no luck. So anytime you move any slider the model turns into that image. And it happens in every viewport. I even tried re-installing, but it still does it. Any help would be great thanks.
Robert![]()
Most of the time when the bounding boxes load it is because a product is being loaded where it can't find the referenced obj(s). What exactly are you loading when you get this. Which product? Have a link to the product if from Daz?
On top of your viewport, you haven't accidently hit a little 'globe' and changed the setting to bounding box?
In Draw Settings make sure that the Manipulation Draw Style option is set to Use Current (Off).
Wow Thanks that was it exactly. Don't know what caused it to change, but now I know how to fix it.
