Skeleton Head for G3M?
Drogo Nazhur
in The Commons
is there a way to put a skeleton skull on a G3M character?
Yes if you have one of these https://www.daz3d.com/midnight-skeleton or https://www.daz3d.com/mr-scallywags.
You can conform them to G3M and turn off the head. Mr-scallywags has it's own morphing skull prop you could just parent to the head
that would be the easiest and it has about 5 expressions and the jaw can move.
Any skull you like can be parented to G3 and then have the head invisible in surfaces, will do the trick. If you want morphs, make sure you get the right skull and will probably have to pay, since there is a lot more work involved with morphs.
Thank you. I have problem with buying a morph. I was hoping that I could just change the head to a skeleton skull with a slider and leave the body alone.
I’ll try the head morph recommendation. Thanks again.
