Searching for this Figure
in The Commons
Hello,
I saw a figure in a promo recently and am interested in seeking it out. Any idea what it's named? And is it me, or does it look awfully familiar to someone- can't put my finger on it.
Thanks for any help.
I think the skin is Maddeliriums Carley, https://www.renderosity.com/mod/bcs/mdd-carley-for-g8f-v8-iray-only/134819/ . The morph looks like it could be Raiya but I couldnt find an exact match. Might be a custom job.
Actually, I think the character is Maddeliriums Carley dialed down to about 55% or so. Ill post a render.
Heres Carley at 55%. Look about right?
Yeah, that's it! Thanks! I kept looking through Raiya's library due to OOT and Raiya's partnering on character bundles- but I couldn't find really anything close, but assumed it may have been an unreleased model.
I absolutely appreciate the assist!
Glad to help!
Actually, follow-up. You said the Head morph for the Carley model is set to 55%. Is there any other model associated in the dials? For instance, if you load the Carley model Victoria 8 will have a default of 35%. Did you maintain that dial? The reason I am asking is so far I am unable to procure the desired result that you displayed. One of the leading indicators is the lips. The Carley character looks to have thin lips by default, and as such is displayed in your result. However, when I have it loaded from the Character pane it loads in with much fuller lips.
Let me know, but no worries if you moved on from this thread
The only slider that I moved was the Carley head morph, I didnt change anything else. I think there might be some other morphs going on in the renders that you posted though. Some sort of youth morph perhaps? If you have Growing Up for G8F, https://www.daz3d.com/growing-up-for-genesis-8-female-s , what happens if you apply a very low level of the yourth morph to Carley 55%? Also, there is a daz youth morph as well if you dont have growing up, I believe its in the face morph list for G8F. You might try a touch of that as well.
How does this look? Better?
