Import/ export "tool" for use with World Creator 2!
DAZ!  Please make an Import/ Export "App" or Tool that would allow DAZ Studio assets to be used with "World Creator 2" and vice versa!  The idea of purchasing pre-built "places" ( -from vendors ) that I'll only use for one or two projects is both expensive and stupid!  With "World Creator 2" users can quickly build the environment they want without constantly forking out cash for such pre-made "place" plug-ins .
  • chris-2599934chris-2599934 Posts: 1,913
    Can World Creator not export to OBJ? Can it import OBJ files? If so, that would be a way to port stuff between the two.
    Alternatively, can you use World Creator to create an HDRI image that you could then use in Daz as a render environment?
  • FSMCDesignsFSMCDesigns Posts: 12,847
    You can already import and export from WC2, so nothing is stopping you from using DAZ assets in it or exporting assets to use in DS. I honestly don't see the difference between purchasing assets from DAZ for use in DS or use in WC2, it's the same amount of usage and you can't share addons with either app, so not sure what the issue is.
