[WTB] Genesis 8 Male breast implant morphs
Hi all,
I'm looking for Genesis 8 Male breast implant morphs, that creates non-malformed tits for G8M, and it's size range is from small to huge. I'd use it in our game, for transgender characters.
I could not find such a morph set not in DAZ store, nor in Renderosity.
I would buy it if someone here is capable to create it - or I'm open to any suggestions how to achieve this result with some existing morphs.
Thanks,
Paul
Contact me, if you would create it: [email protected]
  • There is some sort of set in one of the other stores by an artist name biala.
  • EkhnatonEkhnaton Posts: 4
    Yup, there is a set. I tried it, but two major problems:
    1. these morphed tits are malformed, disgusting
    2. it changes the full body shape along with the tits.
    Genesis 3 Male and Genesis 8 Male are no longer based off of the female mesh so there is not enough geometry to create the morphs you need.
  • GafftheHorseGafftheHorse Posts: 567
    Ekhnaton said:
    Hi all,
    Thanks,
    Paul
    Would the single gender Genesis base not be better for your needs?
  • nicsttnicstt Posts: 11,715
    Would you be better served using a G8F?
    What is it you need (male genitals?)? If so, check out if they are available elsewhere for the female.
  • IvyIvy Posts: 7,165
    edited July 2019
    I did it using deformers and Scaling the deformer. for each L & R pectoral on genesis 8 took me 2 minutes i had to put a bra on him to show you because of the daz TOS
    1876 x 958 - 192K
    Post edited by Ivy on
  • onixonix Posts: 282
    I do not see any reason o brother with transforming male into a female because male characters have very little content available anyway. it is a better idea to use female characters and adjust them as necessary.
    You could try to make some as suggested. There is also Hexagon. The Inflate tool and/or Displacement in UV paint may work. I really think these are the easiest solutions. Any other solution would involve a long winded process of trying to convert something to G8M, and probably still not work as well as you like anyway.
    The other option would be using a G8F for this project. It is possible to convert things to female. There is also a UV Swap product that allows you to use use male skins on females and the reverse. Still, I think the 'create your own' option is best. Breasts are probably the easiest thing to create. (Boy that sounds weird).
    You might want to look up LenioTG, who has done some stuff like that and maybe ask how they did it. There are numerous people making trans characters that might be able to offer advice.
  • plasma_ringplasma_ring Posts: 1,027
    edited January 2020
    biala at Rendo has some female body morphs for G8M, but it depends on what you're trying to accomplish. If these ladies will be taking their clothes off a lot and you're not trying to represent realistic body variety among trans people, you're probably better off using G8F because people have already created lots of genital anatomy options for that base.
    Edited to add: Pretty quickly along the realism spectrum G8F will likely be the best choice anyway, since some gendered aspects of the G8 bases are almost easier to change IRL with hormones than consistently with 3D morphs.
    Post edited by plasma_ring on
  • HaruchaiHaruchai Posts: 2,040
    A quick search of some 3D sites reveals that an artist called Ion has 3 specific transgender characters for Genesis 8 Male at Renderhub. There is also a bundle.
    edited January 2020
    Seeing as a product was requested, I think I can post a link to another site - Hard Breasts (content advisory)
    Mod Edit   You can mention Renderotica but are not allowed to post links to adult sites
    Post edited by Chohole on
