Dynamic clothing
Hello I hope some one can help.
My dynamic clothing tab has disappeared I can't find it anywhere. I have dyunamic clothing control and have tried re installing it. No luck. My dynaic clothing loads as rigging but I cannot see the actual clothes.
Any help greatly appreciated.
Chris
It should be in Window > Tabs > Dynamic Clothing, try loading it from there.
If it still doesn't appear, try changing your Layout from Window > Workspace > Select Layout.
Thanks for responding but I have tried all that. I don't normally have a problem. I should also note that scenes I have saved with dynamic clothing in fail to load. It is like the whole thing has just disapeared.
Have you also checked in Help > About Installed Plugins to see if the DCC has loaded properly?
It should appear near the bottom under Dynamic Cloth Plugin - Basic.
Also, what errors do you get when trying to load a scene containing dynamic clothing?
It sounds as if you installed an out-of-date version - was it downloaded with DS, or as a separate item? You can check its status in Help>About Installed Plug-ins.
Wonderful I checked the about plugins and it seams the serial number was no longer in, which is wierd as I didn't take it out.
Anyway all good now many thanks.
