Bot Robot extra pieces
bicc39bicc39 Posts: 589
Recently purchased Bot.
In viewport, character appears with two extra pieces appearing from the elbow to
the ankle. It is in every pose. It vanishes in the render, but if you export the figure and
import into another program it is there.
  • Richard HaseltineRichard Haseltine Posts: 109,520
    Select the pieces, then go to the Parameters pane (Window>Panes(Tabs)>Parameters and click General>Mesh Resolution on the left, then set SubDivision Algorithm to Catmull Clark (Legacy).
  • bicc39bicc39 Posts: 589
    Thank you for responding.
    Only level available under mesh resolution is "base"
    961 x 676 - 82K
    Sorry, it worked.
    I had been selecting bot instead of Genesis.
    Thank you so much......
    Worked fabulous, thanks again!!!!
    800 x 800 - 97K
