Genesis 8 file error
bryankberry_cc5f01dbec
When trying to open in Carrara 8.5 a Genesis 8 file created in Daz Studio, I get the following error:
Warning: file /data/DAZ 3D/Genesis 8/Female/Genesis8Female.dsf could not be found
Error: node /data/DAZ%203D/Genesis%208/Female/Genesis8Female.dsf#Genesis8Female not found
I checked the file location for Genesis8Female.dsf and it was there. Is there somewhere else that Carrara is looking to find it?
Can I change the file location and point it to the correct one?
So far this is the only Daz file I'm having an issue opening in Carrara.
Appreciate any help!
Bryan
You need Misty's presets to use G8F/G8M in Carrara. Clothes and hairs also needed to be converted to blended weight in DAZ Studio.
https://www.renderosity.com/mod/freestuff/carrara-compatible-character-preset-for-genesis-8-female/77504&ca
https://www.renderosity.com/mod/freestuff/carrara-compatible-character-preset-for-genesis-8-male/77745
There is also a glitch with the toes for the G8F preset.
https://www.daz3d.com/forums/discussion/comment/2885466/
https://www.daz3d.com/forums/discussion/180916/beta-g8f-carrara-preset/p1
http://carraracafe.com/category/tutorials/ ; - look down the page to "How I can use Genesis 3 in Carrara – Tutorial Series by Misty Lara"
haven't found a solution to the g8f toenail issue
if i export her mesh as a new obj the morph takes.
if i re create her morph on her mesh as exists, the same toe issue happens.
there something woring with her toes at the mesh level.
i removed all her other morphs from the morphs folder, that eliminates jcm as an issue.
investigated any possible typo issues.
dunno if carrara model room can give me the vert numbers of those exact verts. there's a total of 10 pollygons on 3 toes not "included" in the morph. so much anguish from 30 polys Lol.
Thanks for the help!
