Black dots in render need solution
Been getting these black dots on the skin of my character
Using: Hi Key studio
I had the same problem around Etta's eyes. Very much dark points and than I figured out, these are not points but holes in the render. If I make a red layer in Photoshop and put it below my render .png than the points are red...
So I used the same render twice as layers and moved the lower layer a tiny bit to the left and the holes were gone. It's not the most elegant solution but it works for me.
I seem to remember that the "holes" are due to using an HDRI with "Draw Dome" turned off. I'm not near my PC so perhaps someone can confirm that?
Thank you both I do have draw dome off and the hole theory makes sense. Will test it and let you know
Worked great thanks!
I found the best solution here you guys pointed me in the right direction
Link for others in need
https://www.daz3d.com/forums/discussion/222136/how-do-i-get-rid-of-these-spots-in-iray-render
