How to apply Mimic Pro export .pz2 to SimonG2, Jessi, Kate, etc.?
Hi all,
I export the pz2 from Mimic Pro and try to apply it to SimonG2.
It turns out that SimonG2 import audio without mouth movement.
How could I set Mimic Pro so that SimonG2's month can move?
Thanks in advance
you need the SimonG2.dmc and the SimonG2.cr2 file
@erdi65: Where could I download dmc file of SimonG2, Jessi or Kate?
(It seems that Daz3D website was changed a lot. tutorials or update files could not be found anymore....)
Not so sure there are any. Or at least I can't find any in my mimic configuration files.
But you need to load the figure you want to use the pose on in to mimic to make the pose. The pz2 from mimic for one figure is not going to work or not work that well on another figure. As in in order for the pz2 from mimic to work on Simon it has to have been made with Simon in mimic.
These links might help
http://ca1-webvirt-forumweb.daz3d.com/viewtopic.php?t=122670&view=next
http://ca1-webvirt-forumweb.daz3d.com/viewtopic.php?t=39996
http://ca1-webvirt-forumweb.daz3d.com/viewtopic.php?t=33636
http://poser.smithmicro.com/tutorials/integration_mimic.html
The old forum had some other info on using them, but I have no idea where to look. I think some one did make a dmc to help with using poser figures
Thanks a lot!
