FIle Location Question For DP SRP G3-G8f
I tried using Content Manager to bring up DieselPunk Space Racer outfit for g3-g8 f,
But that did not place the files in a location where they would operate.
(Often enough, this method works.)
So I was wondering if I should copy and placee the files somewhere else.
...where they would work.
...and where that would be.
  • Richard HaseltineRichard Haseltine Posts: 109,440
    I can';t entirely figure out what is going on from those images, but I suspect that there are extra foldrs inside the zip. The Data, Runtime, and other folders at the same level of the zip go in the Content Directory itself (where they will merge with the existing folders), if they are in a sub-folder of the content directory the product will not work.
  • dash2128dash2128 Posts: 736
    edited July 2019
    So, possibly,
    ....I will need to copy all the files,
    and paste them in one folder?
    (I noticed that when I unzipped the files, they were green, instead of normal black.  I don't know if that means anything.)
    Post edited by dash2128 on
    That may have been the problem!
    Thank you!
    It seems to have worked!
